It is currently Mon May 25, 2026 10:49 am
 Post subject: GM 10 bolt
PostPosted: Sun Jan 08, 2006 10:58 pm
Undefeated in Trivia
I was just offered a GREAT deal on some 10 bolt axles (8.5", not the crappy 8.2"). Well, I THINK its a great deal. $100 for both the front and the rear. I've heard good things about these, but it is not from a very reliable source. What is ya'll's opinion on them? I dont want to blow $100 if they won't be able to handle a mild 350 and some good wheelin'.
Thanks in advance, again.
-Brandon
PostPosted: Sun Jan 08, 2006 11:21 pm
Swap Specialist Mod
they come in the fullsize truck with 350s. theyll hold up good im sure.
PostPosted: Mon Jan 09, 2006 3:22 am
its also vary easy to break those axles in a full sized. I run whith ALOT of full sized Chevy guys and do some wheelin, in a full sized they arent that great. I beat my K-5 whith 31s that had 10bolts and they held fine. On something like a LUV they should work well as theres not much wieght, i just wouldnt run much bigger than a 33" tire on em is all. $100 for front and rear sounds about right.
PostPosted: Mon Jan 09, 2006 6:13 am
Thanks
