It is currently Mon May 25, 2026 10:01 am
PostPosted: Thu Dec 08, 2005 10:33 pm
Swap Specialist Mod
how hard is it to put an s10 hydraulic clutch system onto a luv. is there even room by the brake master cylinder for the clutch master cylinder?
PostPosted: Fri Dec 09, 2005 12:36 am
I used a Willwood clutch master cylinder and a Howe racing hydralic throwout bearing on mine.It was a direct bolt in for my luv, and it connected right up to the pedal. I can get the part numbers from Summit for you.This setup is for the V8 if thats what you are doing.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Fri Dec 09, 2005 12:39 am
Swap Specialist Mod
yeah, its for a v8, but i aint gonna tell what v8 it is :mrgreen: :wink: . do you have the prices for those items?
PostPosted: Fri Dec 09, 2005 3:15 am
Here's the part numbers for Summit Racing.
-Clutch master cylinder-(WIL-260-1304)-$49.95
-Hydralic Throwout Bearing-(HRE-82870)-$147.39
-4AN Russell Pro-Flex brake hose-(RUS-632550)-$25.95
The clutch master cylinder is listed as a brake cylinder but it can also be used for this application.The hydralic throwout bearing requires a 3/4'' bore cylinder which is what the Willwood is.Your going to need the hose ends one is a 90 degree and the other is just a straight hose end.The fitting for the throwout bearing is a 4AN fitting,and the fitting for the clutch master cylinder is a 3AN to 4AN converter fitting.The hose ends are 4AN.There is also a bleeder kit for the bearing, but I just pop the cap on the master cylinder and pump the pedal and the bubbles come up through the fluid resevour.The bearing is for a T-10,Saginaw, Muncie and there is also a bearing for a T-5.The T-10 bearing is for a stock clutch, but a racing clutch bearing is also available.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Fri Dec 09, 2005 3:24 am
Swap Specialist Mod
mkay. well this is good to know. i dont know if the price will sound good to the person, but ill tell him to look at this post.
do you know if they make hyd TO bearings for the nv3500? or are those like that stock?
PostPosted: Fri Dec 09, 2005 3:41 am
Swap Specialist Mod
oh and do you have any pics of how the clutch master cylinder is mounted? id like to see how that works out with the wilwood MC. i looked at the pic of the unit on summit, and it looks to be small enough to where there not gonna be any clearance problems.
i talk alot lol
PostPosted: Fri Dec 09, 2005 3:44 am
Ya,I can get you guys some pics soon just gotta run to the store for some batteries.My camera eats them like candy.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Fri Dec 09, 2005 3:51 am
Swap Specialist Mod
mkay. thanks man! maybe the person i know will break the new tommorow. :D :wink:
PostPosted: Fri Dec 09, 2005 9:33 am
That is too many hints Farmer. I've already figured it out, but I won't say anything. 8)
PostPosted: Sat Dec 10, 2005 4:29 pm
Here you go! 8)
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sat Dec 10, 2005 11:31 pm
Swap Specialist Mod
sweet. that just fits right in there! thats pretty cool
thanks for the pics!
