It is currently Mon May 25, 2026 12:27 pm
 Post subject: 5 Speed Trans
PostPosted: Sat Nov 05, 2005 8:59 pm
Looking to put a 5 speed in my Luv. Any help?
PostPosted: Sat Nov 05, 2005 10:03 pm
Luvtruck.com Wookie
first and more important, you need the transmission, get the flywheel with it it allows a slightly larger clutchdisk and plate. the trans is called the MSD5K.
you need a driveline to go with it. you can get the one from the donor truck, and shorten it 2 1/8 inch, i have one sitting around that was a quality weld job. some machinests won't shorten dropdown drivelines.
do the job like your just replacing the clutch, just swap the 5 in instead of the 4spd and install the shortened driveline and voila.....(this is a totaly bolt in upgrade after you get the driveline chopped).
TiLtEd wrote:
Boobies!!! :D
