It is currently Mon May 25, 2026 10:48 am
 Post subject: the 327 build begins!
PostPosted: Mon Apr 25, 2005 6:06 pm
Alrighty the LUV is going under the knife this weekend. One question about the swap though, im building it as a drag truck, this will be its sole perpose in life from now on. So i was thinking of running no cooling system and no alternator. I have heard of guys doing this before and my dads dragster is set up this way too. Is it a bad idea or no? I wont be running nitrous and i might run a blower so i dont think it will run much hotter than a normal motor, and this will give me alot more room for the distributor whithout firewall modification. Well thanks for the help. 8)
PostPosted: Mon Apr 25, 2005 8:20 pm
The motor still needs to fit between the forward frame crossmember and the firewall. The stock harmonic balancer just clears the forward frame so if you add a blower belt and pulley, you have to mod something. Either wack away on the frame (which isn't a good idea) or work the firewall. Most opt for the firewall mods because you then might as well work it enough to set the motor farther back on the frame.
