It is currently Mon May 25, 2026 11:37 am
 Post subject: Trans oil 4x4 LUV
PostPosted: Sun Mar 27, 2005 6:01 pm
What oil does the manuel transmission and transfer case take on a 79 4x4? I think I read somewhere 30/50 weight but need to make sure? On same subject what does the front and rear axels use?
79 4x4 LUV
PostPosted: Sun Mar 27, 2005 6:49 pm
Swap Specialist Mod
i think it would be 80/90 like the tranny. i might be wrong.
neil
PostPosted: Sun Mar 27, 2005 7:17 pm
The book calls for 30 weight motor oil for the trans. The tcase and the trans share fluid so its the same. 80/90 seems to work. I bought a truck with 90W in the trans once, no noticable ill effects. However, I tend to stick with what they recommend.
The axles take 90W gear lube, or 80/90. I don't think you'd need something like 90/140 or whatever it is unless you live in a real hot area and run the freeway hours on end.
