It is currently Mon May 25, 2026 4:25 am
PostPosted: Tue Jan 25, 2005 2:21 pm
is there a turbo that can be used for the 1.9
i can fab a way to put it in
PostPosted: Thu Jan 27, 2005 9:38 pm
well sure there are quite a few. the one i put on my sandrail i got it from a u pull it wrecking yard for about 80.00. i took mine off a subaru. it`s an ihi unit it works great on my 1.6. if you plan on doing a blow through set up you need to get a high pressure fuel pump and set up a return line back to the tank. you will also need a boost sensitive fuel regulator that will keep the fuel pressure low while not in boost. and bumps it up under pressure. there other tips i can give you if needed. if you go toa self serve auto wrecking yard look for a car with a similar size motor and pull that. there are few sites that can tell you how to inspect used turbo`s to make sure they are good. you would have to do a search for them though. i think dunebuggy.com has one. a couple of other cars that i have used on my rail were also volvo and the chrsyler 2.2 engines there`s a bunch of those around. the later 2 were to big on my 1.6 but they worked fine in my brothers 1.9 rail :twisted:
Users browsing this forum: Bing [Bot] and 20 guests
