It is currently Mon May 25, 2026 12:38 am
 Post subject: G161 Swap
PostPosted: Mon Aug 09, 2004 1:31 am
Help!!!!!!!!!!!!!!!!!!!!!!!!!
I have been slowly fixing up the body work of my old luv and am now getting close to the engine replacement part but have a bit of a problem.
I bought a newer Isuzu G161 from a gemini.
The problem I have is the old engine had mounts at the front and the new motor had mounts in the middle.
Can someone please help me with this or the new engine crane I got will have me swinging by the neck.
I cant believe it doesnt bolt straight in.
PLease god help me find someone in Aus knowledgable in the ways of Luv.
My email is craig.wilson@joewhitemaltings.com.au
PostPosted: Mon Aug 09, 2004 4:06 am
Resident Sparktrician
Contact Noyz. You may not want to hear this, but I think your engine is from a front wheel drive car, and may not work with your application. Noyz may see this tomorrow, but you could send him a PM if you wish.
Later...
Kuranosuke
Grampa's Driving:
1990 Luv 4X4 "Family Cab"
got BOOBIES? 8O 8)
PostPosted: Mon Aug 09, 2004 4:19 pm
I'm going to guess that you've got a truck from 1975 or older. (Maybe a bit off from that, I'm thinking from a US perspective here and they did do a few things different in other countries.) The newer motor is either front wheel drive or it is built more like the 76 and newer LUV G180 motor. You may also find there are differences between the transmission mounting plate on the back of the motor as well. I'm not sure what your solution is going to be, but you might find some helpful people/info over at http://www.hotgemini.com for compatibility help between different years of motors. I'm sure someone over there will know something about what you're trying to do. Over here in the US we're pretty limited to LUV parts knowledge, since we don't have Geminis to work on.
PostPosted: Tue Aug 10, 2004 3:07 am
yes tis noyz here and i have all the solutions to your questions :D however you may not want to hear it.
ive dont the same thing you have and installed a gem engine and my mounts were at the front too!. i had to cut the originals off and re weld them in just past the crossmember with one corner over it (if that makes sense) i hope you have a gem gearbox as the starter is on the other side (that means you have to change the wiring lume to suite) as i havent had mine started, i dont know whether the regulartor off the luv will work with the alternator of the gem. i can take some pics of the mounts and send em to ya just give me ya email
hope this helps,
regards, mark
 Post subject: Thanks
PostPosted: Tue Aug 10, 2004 5:05 pm
Thanks Noyz
Thats exactly what I didnt want to hear.
There must be a better way.
What do the cops think of you changing engine mounts around.
Please dont be offended but Im sure there must be an easier way.
Where are you based man.
Id love to see those photos.
PostPosted: Wed Aug 11, 2004 7:34 am
well the cops dont know, i just made a good job of hiding it.....filler :D
im in melb, wat about urself?
if there was a better way, i didnt find it. some1 told me a small v8 out of a holden will fit the original mounts (some mods mabye) but dont quote me on that.
ill sent those pics to ur email
PostPosted: Wed Aug 11, 2004 11:26 pm
Thanks Noyz
I got your pics.
Thanks heaps.
Im in perth by the way.
Thanks Again.
I just found an 81 isuzu in our local paer for 300 bucks. Im hoping it will have different engine mount possies and maybe even disk brakes.
Cheers Mate
PostPosted: Thu Aug 12, 2004 6:20 am
an 81 isuzu wat...? luv, rodeo...? if its the same or similar, hope it all goes well
 Post subject: G161 swap
PostPosted: Mon Aug 16, 2004 6:10 am
Hey noise.
I hate to play the smart arse but I have gotten around the engine mount moving thing.
A mate of mine is a boilermaker and he is gonna make a set of engine mounts that use the original bottom peice, ie rubber bit, and he is gona make a new bit to mount onto the front mounting holes on the gem motor. Then all I have to do is remote mount the oil filter then find a way of mounting the altenator and im done. Well except for making up a tailshaft. Sweet hey.
So wheres those photos
PostPosted: Mon Aug 16, 2004 7:20 am
:P well its easy for some isnt it! lol hope it all goes well, keep in touch!
as for the photos the film went in for development tonite :D i cant wait to post em, ull all be shocked! :lol:
