It is currently Mon May 25, 2026 4:26 am
 Post subject: alternator
PostPosted: Fri Jul 09, 2004 9:22 pm
hello members, another question on converting a v8 dragger into a street version, the garage is having a really hard time finding a suitable way of mounting the alternator since we had to use a short snout water pump, can any of ya'll remermber what brackets you may have adopted to install your alternator, as always, thanks in advance
http://atlantic.photoisland.com/servlet ... index.html?
PostPosted: Fri Jul 09, 2004 9:42 pm
Both of mine use/d the long thin, curved bracket. But you have to get it bent down where it mounts or like the one I have on the truck now, with a spacer welded on it. Mounts on the drivers side btw
Resident lurker
PostPosted: Sat Jul 10, 2004 12:22 pm
also found a mr. gasket sbc version, with low mount for 50 so that is probably the route i will take SOON....it has only been a "camshaft" (at first) project for 3 1/2 months
PostPosted: Sat Jul 10, 2004 2:37 pm
The best one to use is off of a 68-72 I think it is chevy truck with a v-8 . It makes it out of the way of everything and you can use a electric water pump if you want to .....
GOTTA GET A NEW LUV!!!!!!!!!
PostPosted: Tue Jul 13, 2004 11:27 am
Japanese Redneck
http://www.jegs.com/cgi-bin/ncommerce3/ ... rmenbr=361
this one will work with the short water pump. the only thing I dont like about it is the belt is kinda long so if you spin the RPM up high then it might toss the belt. I personally use a low mount alternator bracket like pn 9758 here http://www.tdperformance.com/TransDapt.html that I modified. there is no belt adjustment though. I had to bump the belt on and if I ever need to take it off, I have to cut it.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Tue Jul 13, 2004 5:31 pm
Image c in the link was the one I was talking about. I does require a fairly long belt though.
Resident lurker
Users browsing this forum: Bing [Bot] and 22 guests
