It is currently Sun May 24, 2026 9:37 pm
 Post subject: 700R4
PostPosted: Wed Nov 27, 2002 8:26 pm
The Luv truck I plan to convert is a diesel is there any differences. I would plan to use a 350 backed by a 700R4 is it difficule to modify the trans mount.
PostPosted: Wed Nov 27, 2002 11:35 pm
The 700R4 takes a different trans mount than the TH350 or TH400. I made my own mount. It wasn't too difficult but it did require some cutting and welding.
If at first you don't succeed, try it like your wife told you to do it.
PostPosted: Thu Nov 28, 2002 3:16 am
I put a 700R4 in mine and i just cut the trans mount back about an inch and drilled 2 new holes...by the way i used the hooker trans mount because thats all i had. be sure you measure it just right because i cut off about a half an inch too much. it was a pain in the ass to fix it with another piece of steel
