It is currently Sun Feb 15, 2026 12:46 am
PostPosted: Fri Feb 16, 2024 2:38 pm
I would like to swap my 4 speed out for a 5 speed. Is this possible?
PostPosted: Sat Feb 17, 2024 9:37 pm
Yes
PostPosted: Mon Aug 19, 2024 10:36 am
Thank you, Joe.
PostPosted: Mon Aug 19, 2024 2:14 pm
I can give you more details, but I didn't want to write a book in the process.
Did you have specific questions?
PostPosted: Tue Sep 10, 2024 1:16 am
Hi, and thank you.
Do you perhaps have a gearbox model name for the 5 speed?
I have tried to search, and just seemingly cannot find good information on gearbox model numbers.
PostPosted: Tue Sep 10, 2024 5:40 am
MSG-5. I'm pretty sure it would be the MSG-5K version. Avoid using one from 1981-1985, because the 1986-1995 versions are much stronger. These were used in Isuzu Pickups with the 2.3 engines. And the output shaft will not fit your original driveshaft slip yoke, but there are different ways to remedy that.
What are you driving? 2wd, or 4wd? Gas, or diesel? My response was assuming 2wd gas.
