It is currently Sun May 24, 2026 8:52 pm
PostPosted: Mon Nov 19, 2018 4:29 pm
Hi all,
I've been through a lot of the forum and am trying to follow the "Beer Budget Truck" explanation... but does anyone have any tips before i get to that last moment i'm shoe-horning?
I specifically interested in wiring ideas? Movement of stock parts in the bay, etc.
Finally, if you are in Washington and are looking for a great condition, freshly pulled G180z from a 1980 Luv, message me. I'm going to put it up on CL and OfferUp this week! Includes everything except the engine mounts... and my buddy wants to Weber 32/36 but for the right price i'll throw it in. Any ideas on how much i should put it up for?
Thanks
1980 Chevy Luv (SBC350 and TH350 mounted!) front suspension install, trooper rear end with 4.10 gearing, needs driveline, brakes, and getting it running!
1968 Datsun Roadster - happy as ever!
1991 Nissan 300zx Twin Turbo (daily as possible)
PostPosted: Mon Nov 19, 2018 5:45 pm
A '80 LUV engine should be a G180Z, never heard of a GS180.
PostPosted: Mon Nov 19, 2018 8:00 pm
Yes. You're right!
PostPosted: Thu Nov 22, 2018 12:57 pm
Think everything out twice before you cut anything . I have a 1978 with a 383 . All the wiring is factory . Only thing I added was a remote solenoid for the starter , but I didn't have to . All the factory gauges and light work as factory . I repined the fuel pump relay plug to call for the fuel pump when the ignition switch is turned on instead of being fired off the alternator charge , but used the factory relays for an aeromotive fuel pump . Flex fan with top half of the factory shroud . all the e brake stuff is factory and plugs right into the 9 inch drum brakes . Just slow down and think every move out or youll have a cut up mess.
PostPosted: Thu Nov 22, 2018 2:26 pm
Thanks hotrod! Good advice!
