It is currently Thu Apr 18, 2024 2:41 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
6.2 diesel or 1.8 g180?
6.2 detroit diesel 38%  38%  [ 3 ]
Stock g180 63%  63%  [ 5 ]
Total votes : 8
PostPosted: Sun Nov 18, 2018 10:52 am
I need a torque pattern and some numbers, anyone got a manual or instructions of some sort?
'75 LUV, Currently waiting for me to put a motor in it
PostPosted: Sun Nov 18, 2018 6:49 pm
Sorry, I only have the FSM for the 78-82. Not sure if your engine has the same torque specs or not. I wouldn't want to take the chance on giving you incorrect info.
PostPosted: Sun Nov 18, 2018 6:54 pm
Thats alright bud, its the effort that counts, thanks. Let me know if ya find anythin, ima keep an eye out.
PostPosted: Fri Nov 23, 2018 5:18 pm
If you want info like which head studs to use check out ozgemini. They do a lot more with the isuzu G engines than we do in the states i know there is a mix of ARP studs that work couldn't tell you which
PostPosted: Sat Nov 24, 2018 5:09 pm
Hey i got another question for yall. Does the new engine bolt into the old engines place? Is the bolt up to the transmission the same? Wiring differences, engine mount differences? Aka would i be able to swap the 76-81 engine into the place of my old style without many problems?
PostPosted: Mon Dec 24, 2018 9:45 pm
Dayofjohn wrote:
Mickey_D wrote:
Are you looking because one of yours is broken or missing? Or is it because they are "stretched"?
If it's because they are stretched, throw those bad boys back in. None of the Luv engines used torque sensitive head bolts. They are reusable.
Deadass? Hell yeah
anybody know where i can find a torque senquence for the head, crank, and connecting rods?
