It is currently Sun May 24, 2026 8:54 pm
 Post subject: V8 fit questions.
PostPosted: Sun Apr 23, 2017 9:01 pm
I recently acquired a 97 suburban to pull the motor and trans from. I'm going to use the EFI with a different computer. I would like to use the accessory brackets so I can convert to power steering also. How much of the front cross member will I need to cut to make it fit? Or should I try another setup?
 Post subject: Re: V8 fit questions.
PostPosted: Mon Apr 24, 2017 10:47 am
It should fit fine. powerbyace.com has mounts. Although I made my own its not that hard. I have hooker headers for mine made just for a Luv but I have heard others fit if you replace the torsion bars with coil overs.
PostPosted: Mon Apr 24, 2017 11:29 am
I don't think the serpentine set up will fit. Even if you eliminate the power steering pump and use an idler pulley there I think it will hit the steering box...
PostPosted: Mon Apr 24, 2017 3:56 pm
Ok, thanks. I wasn't sure. I'm finishing another project right now, so i wont be able to get to this till next summer maybe. I'm just trying to get my ducks in a row before I start. I hope to have the wiring sorted out and a new rear end ready when the time comes to save on down time.
PostPosted: Thu Sep 27, 2018 11:25 am
I bought a 78 Luv, and got a deal on a 283 and a Muncie m20. I bought these thinking I could get the motor & trans mounts from Summit Racing. I just found out the parts have been discontinued. I can weld and fabricate ok, but any advise on this would be helpful, or if someone has the correct mounts I would be interested in purchasing them.
PostPosted: Thu Sep 27, 2018 3:26 pm
Welcome.
Check powerbyace.com
