It is currently Sun May 31, 2026 7:41 am
 Post subject: Long haul luv
PostPosted: Fri Aug 07, 2015 11:22 pm
So for my birthday i took a trailer and truck from Boston ma. to pa. to pick up my new luv thanks to the previous owner who is on here for holding it for me :) i promised to start a topic on this truck to show work and improvements so here we go the pics show when i got the truck, to changing it to a 4 eye nose,bed removal to unclog the fuel return on the top of the tank and so i can sand and under coat the frame. This truck has minimal wrong with the body just a little rust on the back of the bed and the fender bottoms other then that pretty solid. It has the original engine and trans for now i want to drive it as a 4 banger and see what i think before i think of v8'ing it
the carb i have is junk it has been cleaned and replaced the accelerator pump only to find some water had got into the bowl in the last 2 years and froze and cracked the carb body :( im trying to find a cheap stock one to get it going, i don't want to spend to much on the stock motor before i see it drive in case.
There can always be more then 1 LUV in your life
 Post subject: Re: Long haul luv
PostPosted: Wed Nov 04, 2015 9:22 pm
It always makes me happy to see another long bed being saved and restored!
PostPosted: Sun Sep 02, 2018 2:38 pm
Im back and working on her again !! I just bought the power by ace mounts to install a 6.0 ls in the luv doing a twin turbo build so watch for updates :)
