It is currently Sun May 24, 2026 9:37 pm
 Post subject: Simple 5 speed?
PostPosted: Fri Feb 17, 2017 6:26 pm
i know there have been countless threads on the subject but i didnt have much luck finding an answer that directly answered my question
i have a 76' 2x4
and
81' luv 2x4 with a 5 speed
my intention/hope is that the rearend/driveline, and tranny will be direct swap?
ive owned 8 of these trucks and never done this swap due to the fear tearing everything apart only to have un foreseen issues
both trucks have under 100k and run/shift great
any comments are very helpful
thanks. :)
Image Image
 Post subject: Re: Simple 5 speed?
PostPosted: Fri Feb 17, 2017 6:39 pm
Are the starters on the same side?
PostPosted: Sat Feb 18, 2017 10:40 am
I believe the slip yokes won't match, but if you have both driveshafts you should be able to make it work (assuming "yes" to the question that oldestisuzuist asked).
