It is currently Sun May 24, 2026 11:49 pm
PostPosted: Mon Jan 12, 2004 2:38 am
For those in need of plans to fabricate a set of motor mounts to fit a Small Block Chevy motor into your truck, there is a set of drawings in the information section. There's also the part # for the set from Summit if you'd like to order a set. The trans bracket is basicly the same as the stock, early model Luv only the material thickness is greater and the slots for the GM rubber mount. If anyone has any questions, let me know and i'll do my best to answer you. The mounts that i bought will not go into the truck any time soon so they will be at my disposal for remeasuring. Ben has compared the measurements to his own setup and it seems that the drawings should work. Good luck...
PostPosted: Mon Jan 12, 2004 6:49 am
Thanks, I was just thinking about this the other day. I knew someone had some drawings of mounts. Saves me the trouble of sifting through the posts. :D
Resident lurker
