It is currently Sun May 24, 2026 9:40 pm
 Post subject: Compatibility
PostPosted: Wed Jan 21, 2015 11:39 pm
I want to put a 20r Toyota motor in my 1976 Luv. Does anyone know what I will need to do or modify to accomplish this? I have the Toyota tranny also, but don't know if I will need it or even should use it. Any info would be really appreciated.
Luv power!!
 Post subject: Re: Compatibility
PostPosted: Thu Jan 22, 2015 8:19 pm
A 20R should fit fine. If I were doing it I would use the Toyota trans because you know the block and trans will bolt together. You will need to fab motor mounts and trans mounts. It's not a job for a beginner. Some cutting, welding, and measuring will be required.
