It is currently Sun May 24, 2026 9:41 pm
PostPosted: Sun Oct 05, 2014 8:24 pm
Has anyone here switched from a ford 8" to 8.8"? I'm looking at eventually doing a swap and curious what might need to be done to the drive shaft. Also interested in knowing what is involved with narrowing process using the two short side axles.
PostPosted: Sun Oct 05, 2014 8:50 pm
Not from the ford 8, but I am going to the 8.8 shortly in my project LUV from a s10 rear. Shortening the tube is the biggest issue. I have a large pipe cutter and I plan on doing it using that myself. I got the flange for the 8.8 driveshaft with the rear when I pulled it, and an extra short stock axle, going to use a joint that will go from that to a gm style. (I have a good many gm shafts that can be shortened at the driveline shop, will get a joint from them). I put a gm shaft in my v8 Nissan D21 and the driveline shop had a flange that would bolt to the stock Nissan rear and used one of the hybrid joints, until I do this for the 8.8 I don't have a part number...
PostPosted: Tue Oct 07, 2014 7:49 pm
My sugestion is not a ford diff in this case. I have a dana 44 out of a isuzu rodeo in my v8 luv the only thing you have to do is move the spring pads1/2 inch to the center on eatch side. The brake lines hook up directly and it gives you disk brakes a posie and 4.10 or 4.30 gears most commin. I have over 50 passes on a strip with slicks and i drive it every day on the street for 4 years no problems.
Just my 2 cents
Its not MPG, its smiles per mile.
PostPosted: Tue Oct 07, 2014 8:06 pm
Just my 2 cents
I have heard a lot of good about those rears only reason I hadn't considered one is the gear ratio
PostPosted: Fri Oct 10, 2014 7:43 am
Ya 4.30 is a little high even for an OD trany
PostPosted: Thu Jan 22, 2015 1:32 am
Just my 2 cents
Hey, isn't that Rodeo rear end quite a bit wider, like 6 inches wider overall?
When the only tool you have is a hammer, everything looks like a nail.
PostPosted: Thu Jan 22, 2015 8:41 am
"Hey, isn't that Rodeo rear end quite a bit wider, like 6 inches wider overall?"
LUVs are 54" WMS to WMS, 1st gen Rodeos are 58".
Users browsing this forum: Bing [Bot] and 28 guests
