It is currently Sun May 24, 2026 9:41 pm
PostPosted: Tue Apr 08, 2014 5:00 pm
According to the seller, this is a 'LUV 5 speed transmission', but I don't recognize the bell housing, or any of it really. It looks quite different than the others I've seen.
I see a whole mess of little splines on that output shaft though...
The last two 5 speeds I found were the 10-spline variety, with the older style 4 bolt plate in the bell housing instead of the 6 bolt plate that I'm told corresponds to the 86-87 MSG trans many of us are on the hunt for.
Is this the one? JoeIsuzu? Oldestisizuist?
PostPosted: Tue Apr 08, 2014 8:30 pm
I can't tell much from that photo, but it doesn't look like anything I've seen.
do re mi ka do wrote:
...instead of the 6 bolt plate that I'm told corresponds to the 86-87 MSG trans many of us are on the hunt for.
I've never seen the 4 bolt cover on a 5-speed. That 6 bolt cover was used on the '81-'85 transmissions, too (including my '83).
PostPosted: Sun Dec 21, 2014 8:43 pm
It kinda looks like a 5 speed out of a S10.
PostPosted: Mon Dec 22, 2014 3:29 am
Thanks for the resolution, Cleaver. The case itself is pretty different from anything I was able to find during a quick search, but the tail housing and shifter are clearly very similar, if not identical, to those from the S10
Photo via: http://www.autotraderclassics.com/car-a ... 3450.xhtml
PostPosted: Fri Dec 26, 2014 1:33 pm
Chevy T50. info blow.
p.s. my 4.3 V6 had to much power for this transmission. :( pics are of my T50
http://en.wikipedia.org/wiki/Borg-Warne ... ansmission
http://www.v8monza.com/faq-tran.htm
PostPosted: Thu Jan 08, 2015 4:52 pm
Well done cb6tig1! That solves it. That's exactly it, isn't it.
Also good to know it's not a recommended choice.
PostPosted: Tue Jan 13, 2015 9:46 pm
i like the size of it but the most power it can take is like 100hp - 120 torque.
Users browsing this forum: Bing [Bot] and 31 guests
