It is currently Sun May 24, 2026 9:41 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Rear Axle Options
PostPosted: Wed Jul 30, 2014 7:41 am
I believe the fox body rear is 59" axle flange to axle flange. The sn95 models are 3 inches wider.
PostPosted: Wed Jul 30, 2014 10:20 pm
love4theluv wrote:
not sure, im looking at probably getting a s10 rear axle in September or so, trying to track down with with the 3.08 gear because doing 2600rpm at 55 with my 4.10s gets annoying when the speed limit gets to 70 :evil:
I have heard the tbird ifs 8.8 rear mentioned as being pretty good
Try 4:11 like I had in my 65 tempest w 14" tires. Made no difference with the stock engine or the big one I built. 3800rpm to run 70mph. You doing the right thing. I think the stock engine could Handel it. I don't use mine for a truck. That's what my 3/4 ton is for.
PostPosted: Wed Jul 30, 2014 10:27 pm
Looked at the demensions on the 75, series4 truck and it shows 52" center of tire to center of tire.
PostPosted: Wed Jul 30, 2014 10:37 pm
On 12 bolt and 10 too I think a series 2 carrier can use any 2:xx gear set. You will need to run a series 3 carrier to run any 3:xx gear set. And a series 4 carrier to run any 4:xx gear sets. Some one will correct me if I am wrong. It has been a zillion years since I had to deal with GM gear sets.
PostPosted: Fri Oct 03, 2014 12:27 pm
You will need 2.5x-3.08 for 2 series 3.23-4.11 for 3 series and 4 series for 4.56 up
Users browsing this forum: Bing [Bot] and 30 guests
