It is currently Sun May 24, 2026 9:38 pm
 Post subject: swap engine
PostPosted: Mon Feb 24, 2014 11:30 am
Hello this is my frist post, I'm new to the mini truck world and to the chevy luv. I have a 74 luv and I've been thinking of swaping out the engine from a 95 toyota tacoma 2.7 . How hard would that be? Or is there a better choice mortor?? Plz help I would like any ideas. Thanks. :D
 Post subject: Re: swap engine
PostPosted: Mon Feb 24, 2014 3:45 pm
The 22r has been done before, isuzu makes a 2.3 that pretty much bolts right in, and a 2.6 that is efi, you can put the 2.3 intake manifold on a 2.6 and have a carburetted 2.6 that basically drops in they can be found in early isuzu troopers and pups, something like 82-86 and possibly 87-91.... im not sure i dropped a chevy 4.3 in mine
PostPosted: Mon Feb 24, 2014 3:54 pm
so the isuzu 2.6 efi just drops into the luv with out modifying anything? Sounds like that would be the best choice. Does a automatic transmission fit that engine?
PostPosted: Mon Feb 24, 2014 4:01 pm
Im not totally sure im sure one of the isuzu experts will chime in soon. But i believe it goes in with the mounts that come with it. And i believe there is an auto tranny you can pull with it.
The 2.6 is called the 4ze1 and the 2.3 is the 4zd1. Not sure which is more common but the 2.6 with a 2.3 intake is gonna be the most potent combo you will find that goes in easily. Mokadeth a member on the forum also sells aftermarkert offenhauser intakes for them you can put a weber 38/38 on and make more power
PostPosted: Mon Feb 24, 2014 4:44 pm
I see that you have a 4.3 chevy in yours. Is that motor good on gas? What I want in my truck is a gas saver with some hp. this truck is going to be my everyday driver I commute around 80 miles a day to work. I don't want a race truck, I want to make a reliable car.
PostPosted: Mon Feb 24, 2014 4:51 pm
Couldnt tell ya its not finished yet :lol: need to finish a couple things but highway it will probably get 20mpg. Maybe more if i baby it but not much. And it is a lot more spendy to get it in there
