It is currently Sun May 24, 2026 9:39 pm
 Post subject: Rear axle upgrade
PostPosted: Thu Mar 22, 2012 11:51 am
i have a 77 Luv. It is a stock drive train truck., I want to change the gear ratio or swap out another axle for more of a highway gear. 4.56 is awful low geared for the highway. Or maybe swap in a 5 speed. Any suggestions?
 Post subject: Re: Rear axle upgrade
PostPosted: Sat Mar 24, 2012 9:20 am
'77 should have 4.10 gears.
Swap in a 5sp, 5th gear will be like having 3.50 rear gears while still maintaining the power you now have in the lower gears.
PostPosted: Wed Jul 04, 2012 3:02 pm
thanks
PostPosted: Wed Jul 04, 2012 3:14 pm
but do you know what transmission from truck and model can i put in the luv?
PostPosted: Wed Jul 04, 2012 3:23 pm
Try doing a search on the site. This has been covered several times here.
PostPosted: Wed Jul 04, 2012 8:44 pm
Yeah this is a newbie question. That said, you can swap in: 4.56, 4.10, 3.73, and 3.42. I have 3.73 and do 70 on the freeway with the 4 speed no problem. They can be had at parts yards for 50-100 bucks (the third member). 5speed would be good but I think the third member is an easier swap.
PostPosted: Fri Jul 06, 2012 5:52 pm
thanks friends :D
PostPosted: Mon Jul 09, 2012 11:20 am
hey da masta of LUV truck took the parts? thanks
PostPosted: Thu Sep 26, 2013 12:32 am
What is your RPM's like at that speed? BTW, Before ANYONE says it, yes I DO know how old this thread is. :) Thank you for your concern.
My House Is Guarded By A Shotgun 3 Days A Week. Guess Which Days.
PostPosted: Thu Sep 26, 2013 9:05 am
But the thread is so old the guy you are asking does not even own his LUV anymore.
