It is currently Sun May 24, 2026 11:51 pm
 Post subject: suspension
PostPosted: Tue Dec 27, 2011 11:08 pm
1976 chevy luv mikado (stock)
intent is a rodders street truck so drop the front what an inch and raise the rear 2"?
motor swap at a later time (thoughts are) sr20det or sr22det or a 22re supercharged
so what i would be looking for at this point are larger rims (16"), larger disc brakes all the way around, taller gears, lsd (or more commenly posi-trac),and coil overs
i was a racer so the immidiate jump is straight to a irs but budget is kind of low so the intent is a junk yard build so solid axle is probably what its going to have to be
so do i go with a 3-link, or a 4-link rear end to complement the coil
overs?
Friends don't let friends drive stock...
76 mikado, emissions delete, dual alternator, rejetted 1.9 carb swap, non factory body lines
soon non points distributor, single (semi sealed beam) head light conversion
