It is currently Sun May 24, 2026 11:52 pm
 Post subject: In line
PostPosted: Thu Nov 20, 2003 10:21 pm
I was wondering has anyone tried to put an in-line 6 in the luv?
PostPosted: Fri Nov 21, 2003 12:57 am
Hmm... honestly the first question that comes to mind is why an inline 6? I really don't see any advantage in it unless you're getting one free or have one lying around anyway. The inline 6's that I've dealt with are pretty long and slightly awkward. Given the limited space to play with in the engine bay and considering most people usually have to knock the firewall in a couple inches to get a V engine in there, I would stay away from the inline.
Then again, I have yet to do an engine swap on the LUV so I may be wrong. Just my 2 cents...
PostPosted: Fri Nov 21, 2003 8:21 am
I had a full size chevy with a straight six and swaped a v8. The six was slightly longer. There are some performance parts for the six but buck for buck, if possible, go v8.
PostPosted: Fri Nov 21, 2003 9:15 am
Depends on the make of the six, also. I know at least with a Chevy six you have a height issue as well.
PostPosted: Fri Nov 21, 2003 3:21 pm
Sraight six that sounds good BMW POWER maybe no one has done that yet.
PostPosted: Fri Nov 21, 2003 9:43 pm
I was thinking of putting one in from A datsun Z car the oil pan looks like it will clear the front axle and the FI wireing looks simple I think they produce 175HP stock and can be easily turbo charged. But just A thought nothing in the works YET I need to do more looking around.
PostPosted: Sat Nov 22, 2003 11:08 am
I'm not sure but I think some of the motor would end up beside you in the cab. LUV's have pretty small engine compartments and have you ever looked at how long a Z hood is??? Sounds trick if you can pull it off but I bet it will be way to much work.
PostPosted: Sun Nov 23, 2003 12:55 am
I agree with tilted. The 6 out of a z is pretty long and would pose more problems then it would be worth.
