It is currently Sun May 24, 2026 11:52 pm
PostPosted: Thu Aug 11, 2011 1:36 pm
So got lower end built and cam is of to Delta and im about to take the head into shop. I got a G200 head from someone and was about to pull the valves out and have shop stuff them into the 180 head. When I started looking at the valves from my donner 180 head the numbers on the larger ones were the same as the larger ones in the g200 head. The smaller of the valves are different. So what i want to know is what are the size of the valves from a a g200 head. Either measured or the markings on top of the valve themselves. Just want to make sure before I get the work done.
Thanks
OX
PostPosted: Fri Aug 12, 2011 12:12 am
Thanks
OX
i have been told by the guys at ozgemini.com that you can even throw in the valves from the trooper 2.3 4zd1 or 2.6 4ze1 thats what i plan for my g180 turbo build. g200 valves should work fine
PostPosted: Tue Aug 23, 2011 7:13 pm
Went to shop today and we looked up both valves after i pulled the valves from my bought 200 head and the valves are actually the same size even in the book at the shop so no dice there. Should get my cam back from delta tomorrow. Got quoted for 3K paint job today might pull trigger soon!
