It is currently Sun May 24, 2026 11:11 pm
PostPosted: Mon Aug 01, 2011 10:06 pm
I hadn't driven it in almost a year because the ground went out and I was tracking down the issue. Finally I figured that out and tried to run it. Had to replace fuel pump with Mr. Gasket 12S 2.5-3.5 psi pump and I rebuilt the weber 32/36 DFAV carb. Now it has a hard time with full throttle and going 60 mph up hill. Anyone think I need a fuel regulator? It backfires like a sneeze when it's overfueled.
Thanks
Mike
PostPosted: Fri Aug 05, 2011 2:17 pm
buy the Mr Gasket fuel pressure regulator..can't remember the part number.
PostPosted: Thu Aug 11, 2011 6:13 pm
i bought the holey regulator the cheapy didnt work for me. Worked like a champ after that think i went with like 2.5 any more and it would flood it out....
