It is currently Sun May 24, 2026 11:48 pm
PostPosted: Wed Jul 06, 2011 3:46 pm
Guys I was wondering if the 85-to 89 5 speed out of the S series would bolt up to the the 1.9 in my 75? I know that clutch in those trucks are hydraulic(89 at least). Any ideas?
PostPosted: Thu Jul 07, 2011 1:38 pm
OK on wiki I have found out that 82 to 85 s-10s are still using the Isuzu motor (1.9).Are the bolt patterns the same?
PostPosted: Thu Jul 07, 2011 5:51 pm
The 1.9 Isuzu bolt pattern never changed. When GM used these engines they also used an Isuzu tranny. I suspect the hydraulic clutch tranny you have found is BW T-5 and has a GM bolt pattern, probably the same as the Pontiac Iron Duke that was popular about that time.
PostPosted: Thu Jul 07, 2011 9:14 pm
well I didn't find one yet but was curious if anyone had an answer.I will keep looking..not a lot of Isuzu impulses or hombres in SD!
