It is currently Sun May 24, 2026 11:54 pm
PostPosted: Fri Jun 10, 2011 11:01 am
Has anyone put a 22r in a luv yet, my truck only have 82,790 miles stock
PostPosted: Fri Jun 10, 2011 11:22 am
Yes it will, you will need the Toys transmission as well. It does not matter how many miles the LUV has, the Toy engine wont be able to tell.
PostPosted: Fri Jun 10, 2011 9:16 pm
If someone can put BBC in a LUV I'm pretty sure a little Toyota 4 banger will fit lol. Like LuvrV8 said you'll also need the trans and drive-shaft and have the Toy drive-shaft modded to use a LUV U-joint or use the Toy rear end as well.
PostPosted: Sat Jun 11, 2011 12:46 am
yes, there was one at a yard here years ago but the stick shift will set back further by the seat. would be good to put bucket seats in it if you do the swap
PostPosted: Fri Jun 17, 2011 11:55 am
The 20r and 22r are both gesood engines. The 22r is larger in Cubic Inches.
PostPosted: Fri Jun 17, 2011 4:58 pm
I rebuilt a 20r in my wife's 78 Celica years ago. Good eng. The stock carb. sucked. It has a ton of vacuum lines to and from it. IDK what Toyota was thinking when the designed the emissions system for that car/eng. It was a nightmare. But I'm sure de-smoged, it's a great set up.
