It is currently Mon May 25, 2026 12:39 am
PostPosted: Tue Apr 26, 2011 4:11 pm
I put a head w/ the machine work and cam reground that I got off craigslist on awhile back and my luv is not producing the power it should.its got the head n cam,elect.ignition,weber,header,hot coil and 2.1/4 inch exhaust w/ turbo muffler but is a dog.stumbles on acceleration,wants to kinda bog.could the timing chain be off a tooth,or 2 ! have timed it several times w/ a timing lightw/ dwell meter and it seems to run better when timed by hand. ps.the cam was from a 4x4 setup. sounds great,runs poor.
76 mikado project,mean green
PostPosted: Tue Apr 26, 2011 8:20 pm
did you time to #4 and not #1 when you put it all back together ? these need to be done to #4 or it will run bad...
PostPosted: Tue Apr 26, 2011 11:36 pm
shoot,# 1,will try on #4 tomorrow
PostPosted: Tue May 17, 2011 11:43 am
timed it on # 4 w/10 degrees of advance and it seems to be way retarded?
PostPosted: Mon May 23, 2011 6:46 pm
Cat: can you elaborate on timing to 4 instead of to 1?
Directions in manuals are for timing to the #1 cylinder, aren't they.
What is the advantage timing to 4?
