It is currently Sun May 24, 2026 11:53 pm
 Post subject: V8 motor mounts
PostPosted: Sat Feb 26, 2011 3:08 pm
I have a 76 Luv with a small block Chevy conversion, one of my motor mounts is bad and I have no idea what conversion manufacturer the builder used. The motor mounts bolt up to the existing holes on the stock frame mounts with an extension plate thats forward mounted. The rubber mount bolts to the stock small block mounting holes. The forward extension has 1 hole with a small nipple welded to it as a bolt locator. One 3/8 or 7/16 bolt (i'm not sure) screws into the rubber mount which has a nut molded into the rubber. Any ideas?
Thanks,John
 Post subject: Re: V8 motor mounts
PostPosted: Sat Feb 26, 2011 4:10 pm
post a pic of it, that might help...
PostPosted: Sat Feb 26, 2011 8:44 pm
Sounds like a power by ACE mount.
PostPosted: Sun Feb 27, 2011 2:57 pm
http://www.powerbyace.com/
PostPosted: Sun Feb 27, 2011 4:04 pm
Thanks for replying. These images are of my motor mounts. Hopefully someone will be able to recognize them.
- John
PostPosted: Sun Feb 27, 2011 5:00 pm
Not sure about those.
The power by ACE ones bolt up to the stock location. If you can't find the replacement for those, you might have luck replacing both with the ACE ones.
PostPosted: Sun Feb 27, 2011 6:46 pm
how are yours by the way??
PostPosted: Sun Feb 27, 2011 8:50 pm
I have a set of power by ace mounts Im not using. Make me an offer if your interested.
PostPosted: Sun Feb 27, 2011 9:53 pm
The 2nd pic looks to me like a stock Chevrolet V8 rubber mount. You can get those at AutoZone or Oreilly for around $11.
1979 Luv 2wd, rebuilt impulse G200, Weber 32/36, Offy intake, Delta cam, Pacesetter header, Flowmaster, 2 1/4 inch pipe, lowered 4 inches, Bed shortened 10 inches, 1997 Tahoe wheels with 225/50R16 Toyo Proxes.
PostPosted: Sun Feb 27, 2011 10:09 pm
That 2nd pic is definitely a Chevrolet V8 mount. I found it's twin at autozone.com. It fits a 1970 Chevrolet C10 pickup with a 350 engine. Duralast part # 2282. It has a lifetime warranty. Hope this helps.
PostPosted: Sun Feb 27, 2011 10:38 pm
Duralast/Motor Mount
Price:
$6.99
Part Number: 2282
Alternate Part Number: A2282
http://www.autozone.com/autozone/parts/ ... umber=true
PostPosted: Mon Feb 28, 2011 12:01 am
Thanks ethelkilledfred! I didn't know how to post the link or the picture.
PostPosted: Mon Feb 28, 2011 11:50 am
No worries, glad I could help out.
PostPosted: Mon Feb 28, 2011 4:12 pm
Thanks to everyone for your responses, I picked them up and they match pefectly. John
PostPosted: Mon Feb 28, 2011 10:04 pm
Glad I could contribute something to the cause. You're more than welcome.
PostPosted: Tue Mar 01, 2011 4:23 am
Somehow when I read this the first time I thought you were talking about the adapter needed to be replaced. Glad you found your part.
