It is currently Wed Jun 10, 2026 5:48 am
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: What Radiator ?
PostPosted: Mon Jul 19, 2010 11:07 pm
All right guys, It's time for that aluminum radiator for the LUV. I have a "75" with a 350 that's 60 over. Trans, you guessed it, a turbo 350. Plan to run with a separate cooler for the trans. I see that a lot of you out there like the 22 X 19 Griffin radiator. That's great but what I would like to know is specifically what model number did you go with? I know I can't go with a 3" core, too big. I plan to keep my pusher fan and also fan on the motor. I think I need to keep the core size 2-1/2" or under. Any help on this would be great. Brian
 Post subject: Re: What Radiator ?
PostPosted: Tue Jul 20, 2010 1:35 am
this is the 1 that i got. havent installed it yet but looked it over carefully and all the welds look really well done. plus its quite a bit cheaper than griffin
http://www.speedwaymotors.com/Speedway- ... ,3557.html
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Tue Jul 20, 2010 8:49 am
Thanks for the tip. Checked it out at speedway this AM. Did you go with the 22" or the 24". I think a 24" just might fit but maybe somebody out there has done it. I'll let you know what way I go.
PostPosted: Wed Jul 21, 2010 11:37 am
I used a 22 x 19 . If i did it again i'd try and go 24 wide if measurments allowed .
PostPosted: Fri Jul 23, 2010 6:19 am
i personally went with 19 by 22 just cause i dont plan on it being a drag truck just really fast street machine and that should cool it nicely
zyanug
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Fri Jul 23, 2010 9:04 pm
Went with the the speedway THU KOOL 22" X 19". Just got it today and it also looks good. Thanks again for the tip as to where to look for my radiator. I'll post pics when finished.
PostPosted: Tue Aug 03, 2010 12:21 pm
I run a 17 x 18 drag core radiator.
nevr had an issue.
A.j.
PostPosted: Tue Aug 03, 2010 3:25 pm
does this fit without modification?
PostPosted: Fri Aug 13, 2010 10:50 pm
Working on the core support to make the radiator fit. Had to step it down what I could on the bottom side of things ( about 5/8" ). Most, if not all of the upper part of the core will have to be cut out. Still not too sure if the hood will clear the radiator cap, time will tell. I have been busy with work as of late so not a lot has been done on the project. I will try to post pics when I get further along. Sorry, to answer your question yes there is a fair amount of fabrication to be none to the core. I'll let you know.
PostPosted: Fri Aug 13, 2010 11:30 pm
Don't butcher up your core support. Go to www.photobucket.com/v8luv there are some pictures of a 19x22 radiaator installed without cutting out the upper core.
Look at the instructions for installing a V8 in the technical section of www.powerbyace.com
That should give you a good starting point.
PostPosted: Sat Aug 14, 2010 3:53 am
Old Rob wrote:
Don't butcher up your core support. Go to http://www.photobucket.com/v8luv there are some pictures of a 19x22 radiaator installed without cutting out the upper core.
Look at the instructions for installing a V8 in the technical section of http://www.powerbyace.com
Who sells that radiator?
PostPosted: Sat Aug 14, 2010 4:19 pm
Speedway automotive
PostPosted: Sat Aug 14, 2010 11:10 pm
I got mine from Summit Racing, haven't put it in but we'll see how it goes.
Er the Power By Ace site is having issues again, instruction sheet index doesn't work. I do believe the sheet is on the Photobucket site though.
PostPosted: Sun Aug 15, 2010 12:05 pm
Mine is a griffin. I think it is the 19x22. It works perfect and the truck will make pass after pass in the 100+ degree heat (Texas). Be sure its not an expoxy radiator in case you have to have some welding on it. That was a mistake I made when i had to have a 90* elbow put on mine to clear a belt setup I used to have.
PostPosted: Sun Aug 15, 2010 5:19 pm
Thanks for the pics dude, looks great ! I'll post some when I get to that point.
PostPosted: Wed Aug 25, 2010 12:31 am
Here is my radiator....never has run hot even without a shroud in 100 degree weather.
http://www.luvtruck.com/Gallery/Project ... s/luv1.jpg
Never argue with an idiot, he will drag you down to his level and beat you with experience.
PostPosted: Mon Sep 13, 2010 1:14 am
Here is a direct link to the power by ace instructions. The webmaster put a \ where a / should be.
http://www.powerbyace.com/Technical%20p ... lation.htm
PostPosted: Wed Nov 10, 2010 9:43 pm
KMJ has one that is also a trans cooler here is the link
http://www.kmjent.com/cart/product.php? ... 621&page=1
NEW GM CHEVY 22" X 19" ALUMINUM RADIATOR W/ OIL COOLER
Part Number: NOR 209612 it is 169.00
LIVE HARD PLAY HARDER
PostPosted: Tue Nov 08, 2011 3:04 pm
I cut my support for clearance and cooling efficiency purposes. BIG radiator, Stock pan, dist clearance, stock cross members, stock suspension, no firewall hack so everything works. Trans cooler is mounted under bed with electric fan.
PostPosted: Tue Nov 08, 2011 9:21 pm
My current truck had the radiator with it , but i believe the 24 x 19 will fit in if you trim back to th "U" channels on the core support . I have the 22 x 19 with a 10,000 rpm rated flex fan and my truck will idle @ 160 all day long . I also converted my catch can to a recovery tank by adding a dip tube to the brass fitting .
