It is currently Mon May 25, 2026 6:05 am
PostPosted: Mon May 31, 2010 2:50 pm
I found 2 p'up rear ends with 5speed's but when reading topic on the 5speed swap it was said that these might be differnt. but I was still puzzled. if they do work are the rearends 3.73? please let me know and thanks for you help. cuz I cant find gas p'up in the wreaking yard. every p'up around here is working and driven. so will see hope I can find one :(
1975 luv daily driver.
Project-soon to be revived
PostPosted: Mon May 31, 2010 3:41 pm
Go to isuzupup.com and ask Jerry he can answer all your questions and he's a great guy.
PostPosted: Mon May 31, 2010 5:06 pm
Cool, thanks :D
PostPosted: Wed Jun 02, 2010 12:30 pm
was having the same problem up here in norcal. Finally drove 2hrs to Redding Pickn-Pull had three PUPs 2 gas 1 Diesl. Could not get the newer one into 5th so I left it. Picknpull 1/2 off sale so i got rear drive line and 5spd for $200. Keep looking one will show up.
PostPosted: Thu Jun 03, 2010 12:12 am
if there from 5 speed gassers most likely they are 4.11 maybe a 3.73
if there from a diesel it could be a 3.42 3.73 or 4.11
there was a change in the bearings in 86 when the 2.3L was a new thing.
the cases are the same, bell-housings are the same, this up-grade trans can be found in models made 86/95
86/87 its in the pups then 88/95 in the trucks.
it must have a 2.3L engine and 2WD to be the same trans, the only big issue is the yoke.
good info on up-grading your trans.
http://www.isuzupup.com/viewtopic.php?f=36&t=2615&sid=f57bee402272cfaaad39c3d2f9723d8c
most 2WD diesels are 3.73
oddity's are as fallows :egeek
diesels with 3.42s where sold with a 5 speed but had to be a CA spec model with a MPG+ package
3.42s in general are rare, nearly all are found with a 4 speed and are S\B in all most every case.
so if you found a 2WD diesel S\B with a 4 speed, its just about a 100% chance its 3.42 gearing.
gassers had 3.42 as well in some models, but i don't know what had what in those.
3.42s are like a flat land model, and will burn in most cases more fuel in 5th than 4th cause its to tall of gear.
thus why theres nearly none of them. :egeek
4X4s are a given that they are 4.11s ONLY 79 to 87
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Mon Jun 07, 2010 7:23 pm
trooper T/diesel thanks thats some good info the desiel p'ups I found were 1985 with 2.3 motor so am i to assume that the desiel 5speed trany will work and has the 3.73 gears. if so then Im going to pull those parts
PostPosted: Tue Jun 08, 2010 1:07 am
if you change the bell/front case, to a gas with the 6 bolt pattern, yes it will work.
sadly..........4 speeds where made in a 4 and 6 bolt pattern :( the older you go the more that are 4 bolt :(
the difference is in the cover plate, over the front bearings.
so if any trans is 6 bolt 2 or 4WD the bell can be swapped.
that diesel bell is of value, and should not be scraped its an important part to changing a gas pup/luv to diesel.
the bell, the engine, RAD is the hardest parts to find for changing a gasser to diesel.
any trans from a 2.3L will be the stronger 5 speed trans, and will have the right bell.
"true" 85 year models are not 2.3L, there 1.9L or 2.2L diesel.
the only issue with 5 speeds from 81/85 is the diesels can shred the bearings if you like to run at 35/45 mph in 5TH gear.
granted it takes years of this abuse for this to happen.
i would think the gassers will do it as well, just take longer.
86trooperT/D 2.2
PostPosted: Tue Jun 08, 2010 8:38 am
Hold on...are you SURE you found an '85 with a 2.3?
PostPosted: Tue Jun 08, 2010 1:32 pm
JoeIsuzu
not sure :?: will check today or tomorrow. and get back to you. it more than likely will be the 2.2.
PostPosted: Tue Jun 08, 2010 4:00 pm
yes 85 back, there is no 2.3L gas engine.
1.9L gassers have the distributer on the front of the engine.
like this photo
THE 2.3L ENGINE DISTRIBUTER ARE AT THE REAR OF THE ENGINE.
2.2L Diesels looks like this
well ok the 2.2L is missing some stuff :lol:
86trooperT/D 2.2
PostPosted: Tue Jun 08, 2010 7:54 pm
?uestLuv wrote:
JoeIsuzu
Sorry, you did say "diesel". Yep, that would be a 2.2, it's the only diesel ever offered in a P'up or LUV in the U.S.
