It is currently Mon May 25, 2026 2:10 am
 Post subject: some small block stuff
PostPosted: Sat Jun 05, 2010 8:16 pm
can you run the factory ac compressor on a old style small block motor ,..... if not how would you convert the lines over to fit and retain the ac with a newer compressor?
also... did chevy make a four or five speed that will work with the 78 cable clutch setup... do not want to go hydraulic but want a manual
thanks for your help all
PostPosted: Sat Jun 05, 2010 9:16 pm
The Monza's/vegas had drivers side cable clutch pulls, and you can have any shop that make ac lines put the LUV ends on a line to hook up to the gm compressor, or you can fab brackets to make the stocker work, most likely...
PostPosted: Sat Jun 05, 2010 11:46 pm
great... good lookin out on the trans topic indeed... thanks mytmous... Jeremy
