It is currently Mon May 25, 2026 3:43 am
 Post subject: v8 swapppp
PostPosted: Fri May 28, 2010 7:12 pm
my grandfather recently gave me gave me a 283 and i was thinking about putting it into my luv.i was wondering if the stock rearend hold up
 Post subject: Re: v8 swapppp
PostPosted: Sat May 29, 2010 6:31 am
It will hold as long as you don't build up the engine too big, but if it starts to hookup hard it want last long. With a stock 283 it should make for a great around town ride and be very cool.
PostPosted: Sat May 29, 2010 3:32 pm
its not a totally stock 283 its got a mild cam and its bored put a little bit
PostPosted: Sun May 30, 2010 1:54 pm
The 283 even hopped up will be just fine in your truck and the rear will live fine as long as you don't put real sticky tires on it and try drag racing as it will break at some point.
I had a .060 over 283 big cam,14lb. flywheel and a 4 spd. in my truck for 2 years and no problems and i ran it hard but i didn't have sticky tires so they were my safety for the rear and it got good fuel mileage to.
PostPosted: Mon May 31, 2010 5:30 am
You could find a 90=91 isuzu pup that came with the 2.6 and it has a 12 bolt in the rear with disk brakes just a tad wider but you could get that back with back spaced rims.
PostPosted: Mon May 31, 2010 12:52 pm
.125 overbore gives you a 301 cubic inch engine.... They were killer engines in the day.
