It is currently Mon May 25, 2026 12:39 am
 Post subject: Ford 9"
PostPosted: Tue Nov 06, 2007 9:55 pm
Hey Everybody,
I was wondering what were the Ford 9" axles originally in what would I look for to find one??? Thanks.
PostPosted: Tue Nov 06, 2007 9:59 pm
1950s thru the 1980s ford cars ,trucks and vans
PostPosted: Wed Nov 07, 2007 4:41 pm
Were they in Mercs too.
 Post subject: thanks
PostPosted: Wed Nov 07, 2007 5:30 pm
Alright well i'll have to visit my local salvage yards and see if I can pick one up I'd imagine that I should be able to find one.
PostPosted: Wed Nov 07, 2007 6:24 pm
Mercury's and lincoln's too...
PostPosted: Wed Nov 07, 2007 6:37 pm
Did the 9 inch just come in the v8 cars or some of the 6's like the comets and fairlanes had.
I found a comet that has a nice set of tailights i have on my truck and the rear is still under it. The junk yard didn't know he had it
My mistake
PostPosted: Wed Nov 07, 2007 7:18 pm
I haven't seen a factory 9 inch equipped 6 cylinder car, but that's not to say some of them didn't.
PostPosted: Thu Nov 08, 2007 1:52 am
Some 6 banger Ford 1/2 ton pickups had 9" rears and the trk's are going to be the easiest to find 9" rears.
Look close as allot of the Fairlanes and Comets had the 8" rear ends and they look allot alike to tell witch one your looking at is simple if you can put a socket wrench on the bottom nut then it is a 8" rear.
PostPosted: Wed Nov 28, 2007 6:35 am
Location: Colonial Beach VA. If i am not home or at the track then I am probably at HOOTERS!
If you find a comet or fairlane chances are its a 8'' the easiset way to tell is if you can get a socket on the bottom bolts its an 8'' if not its a 9'' most granadas had 8'' too they are also very tough ,good for street use but if you make any power save some time and money and do the 9'' to start with.Find a 57-59 fairlane or galaxie and get the 9'' from under it, its the right width only about 1/4'' wider and most already have a double rib center section I have one in mine with welds off a 68-74 nova and it works fine
74 LUV 355 Bracket Car
WANTED DEAD OR ALIVE 68-74 NOVAS
TOO MUCH IS NOT ENOUGH!!!!!!!!!!!!!!
PostPosted: Wed Nov 28, 2007 8:38 am
What are the advantages to doing this rear end swap?
PostPosted: Wed Nov 28, 2007 2:17 pm
aftemarket parts are a dime-a-dozen and they are virtually indestructable
PostPosted: Wed Nov 28, 2007 5:03 pm
Aside from gears and minor differences like spring location, are there any differences that we should look for?
I guess I am just asking if they have changed through out the years and different applications.
PostPosted: Thu Nov 29, 2007 6:05 am
here's a site that i looked at when i started my 9 inch search.
http://www.kevinstang.com/Ninecase.htm
 Post subject: Re: Ford 9"
PostPosted: Mon Apr 19, 2010 2:06 pm
HA HA...old topic.....
I now have an old Fairlane with a 260 V8 and its got a 9"....just thought that was funny to see this thread again.
PostPosted: Fri Apr 23, 2010 10:02 pm
hop onto craigslist, search "ford 9 inch" and youll be set. expect about 150-300 dollars.
PostPosted: Fri Apr 23, 2010 10:48 pm
Does anybody know what the WMS to WMS on a stock luv rear axle is? I don't feel like going out and measuring at the moment, thanks
PostPosted: Mon Apr 26, 2010 12:47 pm
if i remember correctly inside backing plate to inside backing plate is 52"
PostPosted: Mon Apr 26, 2010 9:30 pm
54" WMS to WMS
PostPosted: Mon Apr 26, 2010 10:43 pm
Thanks guys
