It is currently Mon May 25, 2026 9:33 am
PostPosted: Thu Feb 25, 2010 10:41 pm
I have a 72 luv, and i've heard that they are a little different from the other years so I'm wondering what the lowest rear gears I can get under it is without having to modify too much... Also thinking about a 5 speed. If I'm mistaken about the 72 being different, please let me know, I have looked through the upgrade threads but am just looking for a definitive answer. Even a specific model and year that I would pull it from if it needs to be that specific.
Thanks guys
PostPosted: Fri Feb 26, 2010 12:18 am
Well the lowest gears are the factory 4.56. I think you mean the highest. I have 3.73s out of a 83 Pup with no modifications except taking out two of the mounting studs and replacing them with bolts. The 72 rear axle housing is identical to the other LUV years.
PostPosted: Fri Feb 26, 2010 12:36 am
oh, yes, highest, thanks.
Thanks for your help
PostPosted: Fri Feb 26, 2010 8:18 pm
3.42 ratio is the highest. I found one in an '84 Isuzu pickup, 1.9 engine with a 4-speed. I think it was called an "MPG" version. Same year with a 5-speed has a different ratio. A '78 LUV with an auto came with 3.73 gears, manual had 4.10's.
PostPosted: Sun Apr 04, 2010 5:25 pm
any 2WD GEN2 81/82 luv or 81/87 pup with a mpg+ stiker
(its on the cab, behind the doors, at the top of the bed)
has the 3.42s
there all 4 speed,
other than one odd ball.
the diesels sold in CA state that are a MPG+ model have a 5 speed.
why, i have not a clue, other than "mabe" lowering RPMs to pass emissons.
in short finding a 3.73 will be much easyer than a 3.42
3.73s are a good middle ground, if you move any (real loads), you will not be happy moving a big load with 3.42s 1ST and reverse will be, much much taller.
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Sun Apr 04, 2010 5:53 pm
I found a 3:42 fairly easily on car-part.com. I searched on luvs from the 80's and found a few to choose from. I picked an 81 carrier and it was a fairly easy swap.
Users browsing this forum: Google [Bot] and 31 guests
