It is currently Mon May 25, 2026 12:39 am
 Post subject: 89 pup Five Speed
PostPosted: Mon Mar 15, 2010 3:14 pm
The 89 will be a 2.6L TF model. They had the MUA trans. These were fitted with a remote shifter. (I do believe that you guys got some TF's with T5 gearboxes.)
Trying to get this to work from 89 pup
What would I have to do to get this to work? I have a 78 4 spd im almost 100% positive its a cable assemblie.
Can I swap the trainy to cable or do i have to swap the pedal and install resevoir...
Thanks
 Post subject: Re: 89 pup Five Speed
PostPosted: Tue Mar 16, 2010 8:24 am
Nope, no '89 P'ups. That was perhaps a Pickup.
Converting the truck to hydraulic clutch would probably be easier than fabbing up a way for a cable to operate the MUA transmission. Does the MUA housing even bolt right up?
PostPosted: Tue Mar 16, 2010 11:16 pm
2WD trucks in 88 to 95 where sold with a.......
2.3L and MSG
and the 2.6L with MUA
there are a small amount of 88/95 4x4s with a GM 3.1L V-6 "should" have a MUA
the only isuzu stuff to have a T-5 B\W bolted to it IN THE USA.
was the G.M. S-10 trucks with the C223 diesel, and some of the isuzu rodeo SUVs
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
