It is currently Mon May 25, 2026 1:27 am
 Post subject: 80 luv 86 pup 5 speed
PostPosted: Tue Jan 19, 2010 2:34 pm
I have seen alot of examples but I wish to get down to nuts and bolts.
I have 80 luv, some parts on it seem to be 81 luv but title says 80. so I think of it as late 80 luv.
I found a 86 pup 5 speed. The wrecking yard says it is bolted up to a 1.9 L motor. I don't know if they know what they are talking about. I don't think 1.9 was in 86 but I also no nothing about pups.
it looks like late 70's luv. the drive line is different then a pups. a person has to change yokes ir custom biuld a driveline. I have been trying to do my homework before doing a post.
I know that luv changed some stuff in the 80's.
ok enough leading to this
what needs to be changed on a 1980 luv to fit a 86 pup 5 speed trans in it?
Can I use pup driveline without changing?
Can I use the Luv driveline with no changes?
do I have to get a custom driveline?
viewtopic.php?f=6&t=21297
this link talks about distance between yoke and trans
just a reminder to those how normally work on old v8s. Trans takes motor oil. I lesson I learned the hard way. Rebiuld the 4 speed by a shop, $500.
order new trans $500 plus shipping
1986 PUP 5speed trans out of a wrecking yard $150 plus time to remove it.
PostPosted: Sat Feb 13, 2010 1:35 am
as far as i know 1987 was the last 2WD 1.9L year
1985 was the last 4WD 1.9L year.
81 was the first 1.9L year :?:
1986 was the first 2.3L year with the stronger MSG trans that was sold 86/95
86/87 2.3Ls where sold as a 4WD for those two years ONLY :!: a 2WD trans from these two years will have the right yoke.
88 up to 95 the 2.3L is a 2WD engine only they have a yoke thats mated to a bigger drive line.
its a very commen up-grade for the 81/85 2WD diesels
the trans is 100% the same on the out side as the 81/85 transes
http://www.isuzupup.com/viewtopic.php?f=36&t=2615&sid=29d7311fb5c119f4807cf90b0144cc4f
if your trans is a 4 speed there about 5" shorter than a 5 speed.........so :(
best thing is to get trans, drive line and rear end from the doner.
my 0.01C
some more info
http://forums.luvtruck.com/viewtopic.php?f=6&t=14306
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
Users browsing this forum: Google [Bot] and 20 guests
