It is currently Mon May 25, 2026 1:25 am
 Post subject: drive line shops
PostPosted: Tue Jan 19, 2010 11:29 am
I'm looking for a decent drive line shop in the dallas area that can cut and re spline my axel shafts and build a drive shaft for me. Help would be greatly appreciated
 Post subject: Re: drive line shops
PostPosted: Tue Jan 19, 2010 3:04 pm
Not sure if a drive line shop is setup to do both. I"ll see what I can find out. Do you have a narrowed rear end and need the axles cut and spline to match?
PostPosted: Wed Jan 20, 2010 12:33 pm
I have and independent rear out of a 300z. You can check it out in the project build section here on the site.
PostPosted: Wed Jan 20, 2010 9:34 pm
You are going to need a "good" machine shop. That is basically IRS like a older VW's use, or the Corvette uses. Almost the same as FWD cars use too. I have seen Vette's have replacement shafts made, but built with drive shaft u-joints instead of the CV joints....
Someone will have to look and see how much metal there is to work with. A shop may be able to replace the shaft part or cut and weld it. IIRC part of the joint is made into the shaft...
PostPosted: Wed Jan 20, 2010 10:02 pm
I have been looking into this a little. There are several ways it seems people do this, from 1/2 shaft conversions and others things.
This looks like the best look at this type of rear end setup, and some mods.
http://www.88hybrid.com/forum/viewtopic.php?t=6374&sid=ae2e378296e91cc756b7021f9230c1b2
hth
