It is currently Mon May 25, 2026 12:38 am
 Post subject: header clearance
PostPosted: Thu Jan 14, 2010 10:22 pm
on average you v8 fellas ... how far do your headers drop past the frame and how much ground clearance do you have from pavement to bottom of headers
 Post subject: Re: header clearance
PostPosted: Thu Jan 14, 2010 11:53 pm
I will have to go out and measure mine forsure but if you turn the flanges the right way, if I remember correctly, the bottom of the flange is less than and inch below the frame. I also think the deep pan on my powerglide is slightly lower than the flanges...
PostPosted: Fri Jan 15, 2010 10:14 am
hmm. sounds like im gonna have to get creative when i bag the truck. almost makes me think that bagging it first is a better idea so i know how much room ill have when i go to drop the motor in. that way i wont have to re-do anything. id rather have custom headers made than putting on v8 swap headers and then they hang too low and have to re-do stuff anyway
PostPosted: Fri Jan 15, 2010 6:52 pm
Depends on the size of the custom headers, too. I have 1 tube that runs over the frame and back under on each side...
PostPosted: Fri Jan 15, 2010 7:50 pm
I'll let you knoe Sunday :D
