It is currently Mon May 25, 2026 12:38 am
PostPosted: Sun Dec 13, 2009 5:00 am
Australian LUV Guru
Has anyone fitted a diff from a Mitsubishi (Dodge Ram ???) into a Luv?
I measured the distance between spring pads on the stock diff from my Bro,s Mitsi burnout/drag ute today, and its the same as my Luv,s.
File comment: Mitsubishi (Dodge Ram ??) Drag/Burnout Ute
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Mon Dec 14, 2009 3:34 pm
you know im pretty sure nobody on here has, i havent seen much trans work done on this site, you should definately try it out and tell us how it goes...
"If it wont fit, force it, if it breaks, then it needed to be replaced anyway..."
PostPosted: Mon Dec 21, 2009 6:32 pm
i don't think he is doing a trans he is thinking about a rear-end out of a d-50/mitz i was thinking of putting my luv on a 93 mitz with a 2.6 and 5 speed just a thought
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Mon Dec 21, 2009 11:01 pm
I think you may find that flange to flange is wider than the LUV rear end.
PostPosted: Tue Dec 22, 2009 8:53 am
and the yoke is nuthing close to the luvs, so a drive shaft change may warrent as well.
A.j.
