It is currently Sun May 24, 2026 11:11 pm
 Post subject: 1.8 Performance again
PostPosted: Tue Aug 05, 2003 10:00 pm
ok so I have a 79 luv with a stock 1.8 and i want some more horsepower without having to spent all the money I make in a year for a new or even used engine so what do you thing I can do to get at least some more power!
PostPosted: Tue Aug 05, 2003 10:33 pm
Make sure that what you have now is putting out the best it can. Go for a major tune up. Fresh filters all over the truck, make sure you dont have any air leaks anywhere (gaskets and bad hoses), make sure you have a properly working cooling system, Make sure your tranny and rear end have sufficient lube. It wont cost that much to do just this. You may not see much of a performance gain but at least you'll be ready to build from that.
PostPosted: Tue Aug 05, 2003 10:39 pm
I dome all of hat plus some just to get it to run so that is why i want to step it up a notch
I done all of hat plus some just to get it to run so that is why i want to step it up a notch
PostPosted: Tue Aug 05, 2003 11:03 pm
If it's possible (emissions testing wise) you can build your own exhaust system that has a fatter diameter tubing with a less restrictive muffler. You can get some power gain for around 100 bucks if you buy the parts and install it yourself. This will show an increase for the money. I was clowning around with my truck when i first got it and i would shut off the ignition while driving down the road in gear. I would turn the ignition back on and the truck would backfire and scare the crap out of anyone near by. I did this one too many times and i split the muffler. I drove around like that for months and i had to fix it. I replaced the muffler and i thought that a boat anchor was part of the installation. A fresh muffler robbed a ton of power from the truck. A new exhaust will show the most improvement of the least amout of money.
PostPosted: Tue Aug 12, 2003 4:30 pm
new exsaust will make a huge difrence. also when that is done i find that my truck when i use the hight octain gas it back fires hella!! you should get bigger plug wires and a msd master blaster coil. that will hel and get nicer spark plugs go to your local muffler store and ask for a spin tech muffler that is one of the best mufflers for the luv with 2 1/4 inch pipeing that will add some power and some soundw if you get that done your luv will be hella throaty. :lol: you will be impresed
PostPosted: Wed Aug 13, 2003 4:51 am
I posted a link to a header for sale on ebay yesterday.... :D
in the auction section
03Cobra
