It is currently Mon May 25, 2026 5:18 am
 Post subject: weber copy
PostPosted: Fri Mar 06, 2009 1:09 am
my holley/motorcraft weber copy has 3 spots for hoses/ lines.2 large and 1 small underneath. the small underneath I believe is vacuum advance,the top one on left is fuel in,would this make the last one fuel return? keep in mind the linkage is towards the front on this carb.
76 mikado project,mean green
 Post subject: Re: weber copy
PostPosted: Fri Mar 06, 2009 1:41 am
the norm is 2 in for fuel , only one is used but it gives the option of which side to run the line into... then there is a fuel return and all most all of them have not been taped into... out of all the webers i have had only one had the return line taped for a hose
PostPosted: Sun Mar 15, 2009 8:09 am
doesn't look like mine there must be alot of variations of this carb though.
Juice
