It is currently Sun May 24, 2026 9:38 pm
PostPosted: Wed Sep 04, 2002 10:06 pm
what is the biggest rim and tire combination that would fit on a stock rearend in a 78 luv....and what radiator will fit in a luv without major mods....and is there any way to fit a v8 in a luv withougt firewall mods?...im new to this page...and its great...i have a 78 chevy luv mikado with an automatic yellow in color...hopin to keep it lookin all original and go fast.....also...do they sell aftermarket engine parts for the isuzu inline 4s...sry for bein so long winded....tim
 Post subject: fat tires
PostPosted: Wed Sep 04, 2002 10:19 pm
I dont know what the largest combo is, but i have 14" rims with 26" x 9" slicks. They tuck under just perfect with little mods. I believe you can get away without modifying your firewall if you run a points style distributor, although if you run an electronic you'll probably have to massage it. I run a Griffin 19" x 22" radiator. You can find pictures of my truck at http://photos.yahoo.com/barlienringo Hope this helps, Bryan
PostPosted: Wed Sep 04, 2002 11:08 pm
i used to run a 275-60-15 on steel wheels with the stock springs i had taken out two leafs to lower it and left the bottom out stops in it did not hit the tires it would bottom out first .now i have 28/12.50/15 street slick with 4-link and coil overs there are pics in photo forum my name is howard king
PostPosted: Sat Sep 21, 2002 2:24 pm
Japanese Redneck
I run a 275/60-15 BFG drag radial on a 15x8 5" rearspacing Weld Wheel for street and a the same wheel and a 28x10 Goodyear eagle drag slick for the strip (or that big money street race) I believe that is close to the 28x12.5-15 ET street as mentioned above. It has a narrowed 9" though so not sure what rear spacing to use if you have a stock rear end but in a nutshell you can get a 10" tire in there no problem. I did have to buzz the lakewood slapper traction bars a tad bit though.
