It is currently Mon May 25, 2026 4:30 am
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
 Post subject: Re: help on a v8 swap
PostPosted: Fri Feb 27, 2009 2:07 am
You do not need to cut off the original motor mount. There are adapters that bolt to them and correctly locate the engine. Using the factory torque plane. The transmission adapters are also bolt in.
www.photobucket.com/V8luv
