It is currently Mon May 25, 2026 4:33 am
PostPosted: Sat Feb 14, 2009 6:50 pm
How much transmissions fluid those a th350 hold
and if it has a 3'' pan how much more fluid shoul i add?
PostPosted: Sat Feb 21, 2009 1:58 am
If it's a fresh rebuild with a rebuilt 12" converter you're going to need approx 11 to 12 quarts. 11" stall converter would be on the 11 quart side. The deeper pans usually add 2 quarts as you run them one quart low on the stick.
PostPosted: Sat Feb 21, 2009 2:06 am
What about with and external cooler?
PostPosted: Sat Feb 21, 2009 9:55 am
On a TH350 (with stock 11" converter) deep pan and cooler 12 quarts should be right on give or take a 1/2 qt.
PostPosted: Sat Feb 21, 2009 3:32 pm
i drained it and got like 8 quarts(geuss)
i put five in and no marck so i guess i still need more?
i just dont want to put to much, so add more right :signanyone
PostPosted: Sat Feb 21, 2009 8:57 pm
If the converter is full(actually about 1/2 you are about 1-2 qts from full.
