It is currently Mon May 25, 2026 4:32 am
 Post subject: NEW RADIATOR
PostPosted: Fri Nov 07, 2008 12:32 pm
ok i love my luv but cant drive it for any length of time as it get way to hot{had it up to 240 deg} so what i was wondering is some of y'all that have the aluminum radiators what are the measurements length and width and what all did you have to cut and modify to get it in place, and do any of you have had same problem how have you fixed it?
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
 Post subject: Re: NEW RADIATOR
PostPosted: Fri Nov 07, 2008 4:18 pm
We don't mind answering questions but I think on this topic, the search button is your friend.
Let me know if you can't find anything.
PostPosted: Sun Nov 09, 2008 12:20 pm
was kinda lookin for peoples opinions b4 i hacked up my front end to find out i did it wrong. found lots of people have aluminum rad's but couldn't find anything that siad what size or what they had to cut
zyanug
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Sun Nov 09, 2008 10:39 pm
viewtopic.php?f=6&t=57&hilit=griffen+radiator
PostPosted: Fri Feb 13, 2009 2:37 am
I read your comment on aluminum radiators? May I make a suggestion since I am running a 383 sbc in my 78? The radiator out of a 67-70 Mustang with a 390-428 engine will fit right between the uprights of your front end! You do have to take the radiator to a shop and have the outlets changed from side to side and re-sized though. I am using the same radiator for 3 years here in So Ca and even with the a/c on during the hot summer months the engine temperature rarely exceeds 200 degrees.
I am not computor literate, (old as dirt,) and I cannot seem to get pictures on this site, but I can e-mail them, if you are interested please contact me at pinkertondusty@aol.com.
I have several pictures of my radiator and engine set up.
Good luck, I love those 327s, I think they are one of the best engines ever made. I also have several camshafts for sbc, including a new 350 horsepower, 327 engine if you are interested, send me a message?
dp
