It is currently Mon May 25, 2026 6:08 am
 Post subject: V8 hooker headers
PostPosted: Mon Aug 18, 2008 5:30 am
Managed to get the driverside on :roll: . Does the driverside torsion bar have to come off to get the header in with the motor in the truck ?
 Post subject: Re: V8 hooker headers
PostPosted: Mon Aug 18, 2008 2:06 pm
Chirp.......Chirp........Chirp.......
PostPosted: Mon Aug 18, 2008 2:44 pm
I THINK I remember Ben saying he could never get the headers in with the motor in.
PostPosted: Mon Aug 18, 2008 7:26 pm
Torsion bar has to come out for the passenger side fender to go in with motor in place . But there in .
PostPosted: Tue Aug 19, 2008 4:26 am
It is way easier to pull the torsion bars than fight it .
PostPosted: Tue Aug 19, 2008 10:57 am
I don't know on a Luv. but I had a Dodge Dart with a 340. The first set of headers that had a tube that you could remove to get around pulling the torsion bars lasted 2 years. The 2nd set lasted as long as I owned the car, but you had to pull the torsion bars. It was a lot easier than I thought. I broke one before then, and it wasn't as hard as I thought. I later put 6 cylinder bars on it for drag racing.
Pull the bar.
PostPosted: Wed Aug 20, 2008 6:22 pm
sorry hotrod been busy with my swap...motor has to be out to do it easy if not remove the torsion or lift the truck up and then lift engine up. just got mine in and had to grind some of the crossmember off for the tubes to clear.
PostPosted: Thu Aug 21, 2008 4:44 am
I got them in . I tried the jack the motor up deal , and it won't move that far .
PostPosted: Thu Aug 21, 2008 1:55 pm
What oil filter do ya'll run?
PostPosted: Thu Aug 21, 2008 4:32 pm
i run the fram ph30, hotrod what size cooling fan you running? i have a 12" and a 16" one i have to cut some to fit the other i don't.
PostPosted: Thu Aug 21, 2008 8:41 pm
7 blade flex fan .
PostPosted: Fri Aug 22, 2008 3:58 am
how did you get it to fit, i don't have much room.
PostPosted: Sun Aug 24, 2008 7:55 pm
Hotrod I got mine in after jacking the truck up in the air and bring them in from under the truck. but i think i am goin t do away with mine and have a set of finderwell exits made to make changing plugs and oil filter alot easier. just thought you would like to know if you have to pull your motor out again or anything like that. hope i was to some help
William "Crazy Cooter" Nelson
PostPosted: Thu Aug 28, 2008 8:41 pm
Hey double W , thanks for the info , Oh and welcome to the forum . I had to massage the oil pan to get the filter in . The new motor will get a remote setup . Sorry about the phone call CT i was super busy this week end .
PostPosted: Fri Aug 29, 2008 7:06 am
I have an 80 4X4. When I installed My 4.3 I tryed to use the hooker headers but the headers hit the bars. I couldn't istall the headers with the eng in and could't install the eng with the headers on. so I used the stock 85 C-10 tub manifold that came with the eng. I have a 79 4X4 and have throught about installing a 94 5.7. I am planning on finding a set of block hugers headers if I ever get that far.
The only way to truely know your vehicle is to take it apart and rebuild it from the ground up!!!!!
80 LUV 4X4 Mods(Holley fuel injected 4.3 700R4/ 208 Transfer Case)
79 LUV 4X4 Mods (350 Project)
PostPosted: Sun Feb 08, 2009 11:10 pm
The Hooker Headers that I have used are made for a chevy v8 swap into a 72-80 Luv. These have a two piece header for the right side so you won't have to remove anything to install them. The back tube, number 8 cylinder, goes over the frame and connects back into the headers by the starter. This facilitates removal of the starter too, if you ever have to change it.
You will have to cut away a small part of the inner fender to install this tube. I have also trimed the left side inner fender so I can replace the oil filter easier, I just cannot get the filter out through the bottom, no room between the block, headers and torsion arm!
AS suggested, go to the article included here and read up on the Hooker system.
Hope this helps,
dusty-scjconv
