It is currently Mon May 25, 2026 3:45 am
PostPosted: Mon Oct 06, 2008 8:29 pm
well I am debating about how to match my lug pattern on my truck it has an s-10 rear axle from a 93 and it is 5 on 4.75 and the stock luv up front of course is 6 on 5.5 so I thought about a spindle swap and I like it but I don't know if I can trust it.
I kinda wanna be able to bolt on and go.... So I cross referenced bearings for rear on the s-10 rear axle and bingo it came up with almost all the isuzu's that use that gm axle. but I am not for sure it would totally fit but if so I could have same bolt pattern all around and have disc brakes in rear as well? best of both worlds with a v8 sounds great!!!! hope someone can chime in on this.
PostPosted: Tue Oct 07, 2008 5:35 pm
um forget this idea I was kinda :alcholic when writing that excuse me
but I did call autofab for the aerospace brakes they will get back to me once they find out the right setup for the luv they told me the luv had 3 different types of spindles on the front crazy
