It is currently Mon May 25, 2026 3:45 am
PostPosted: Sat Aug 09, 2008 4:55 am
I am currently looking at a set of mazda pickup wheels that are 6 bolt was wondering if they would fit on a luv ? sorry if this a dumb question.
PostPosted: Sat Aug 09, 2008 10:07 am
The bolt pattern is the same.If the backspacing will work on your truck is kinda trial and error based on what tires you are running and if the truck is lowered or lifted.
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
PostPosted: Sun Aug 10, 2008 8:51 pm
most wheels that are 6 lug will fit i had a set of GMC stockers on my luv with low pro tires and i just found a set of center line rims a guy had on his 4x4 chevy blazer so it is try it get a fell of it to see if all is good no rubbing if they are off set to far out then when you trun might rub ok i hope we helped you sum and if you dont know ask we all have been there at sum time ok ttyl :ebiggrin
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Mon Aug 11, 2008 4:24 am
thanks for the help guys. I picked up the set of mazda wheels today ill have some pictures once I get them installed.
PostPosted: Mon Aug 11, 2008 10:35 pm
Here are the pictures as promised. I think it looks pretty good.
PostPosted: Tue Aug 12, 2008 7:45 am
This is the rims I am running. they are from a 2000 Silverado 16" not sure about the backspace or width but they tuck under the fenders with about an inch from the outside fender lip and do not rub up front lock to lock with a 3" drop all the way around. I am running 215/65/16 which are less than an inch diffrence in diameter than stock tire size.
PostPosted: Tue Aug 12, 2008 11:13 am
Tim looks good.
Bama:
Sometimes the major tire changes have take off wheels when the owner goes to different wheels I saw some at Discount Tire that seemed fairly cheap. They were GMC
PostPosted: Tue Aug 12, 2008 12:36 pm
Tim Chunks wrote:
Pop your head under the back and check to make sure youve got well over an inch or two between your tyres and the springs and chassis. Check the keepers around the springs behind the diff. They line up with the tyre and if the bolt is in, nut facing out, it will be close to the tyre.
I put some similar looking Toyota rims on mine and the tyres rubbed the sidewalls on the inside. You would be surprised how much the diff moves side to side while driving, even if you have good shackle bushes in the springs.
And you might want to get under and wind the front torsion bars off a bit, i rekon about a 2" drop, that will get it looking spot on. :ewink
Cheers, Bob.
PostPosted: Tue Aug 12, 2008 3:05 pm
The rears have quite a bit of space so I don't think rubbing in the rear will be to much of a problem.
As far as winding down the torsion bars how do I do that?
I can acutally drop the front of the truck down just by adjusting these bars?
Thats pretty sweet. Tim
PostPosted: Tue Aug 12, 2008 10:38 pm
Heck yeah ya can! Just do a search in the forum and you can find a TON of good info. Everything from simple lowering (or raising) to re-indexing and coilovers.
1975 LUV with a caddy 500ci, 12.5-1 comp, 850CFM holley sucking E85 through 110 jets and torquing the hell out of a TH400. Currently @ 6mpg
Bowties may be for little boys, but ponies are DEFINATLY for little girls....
